sonolink
I have this Overdrive pedal on my bench and can't figure out what's wrong with it.
Symptoms are no sound when on. Sound only when in bypass. LED works.
I have measured voltages on the opamp and readings when on are around 4v on all pins except pin 4.
I checked continuity between the input jack and the circuit input and between the output jack and the circuit output and the switch board seems fine.
I have used an audio probe to send a signal from the input into an amp and I can hear the signal on my amp.
I have measured the diodes and the read 0.6 with the black lead on the cathode and OL the other way around.
I have measured the black diode near the DC input and this one reads OL both ways (I didn't take it off the board).
Any ideas please?
Sono
Any ideas please?
Sono
