This is my own Franken-amp design so there's no precise 'original' to compare things to. It's a 6at6-12ax7-6v6 lineup.
I dig that the SS rectifier is going to put out a lot more voltage than a tube rectifier.
Without the tubes in, I'm seeing 550v on the 6v6 plate, which is rated for a max of 500v.
I've read that they can handle 550v AND that once the tubes are in, the overall voltage would drop back down into normal operating range.
Trying to get some expert advice before I put any tubes in!
Schematic is attached.
