I am working on 2 paired T bone sc 600 now. I would like to change the two 220uf 16v capacitors for better ones (they have to be small, 8mm diameter and 12 mm high would be great) . I am searching on mouser, which is cheaper than the two others. I found some, but they are of higher voltage... is it a problem. Or chould I take others ?
Maybe consider starting a separate thread for this different topic?
Either way, i'd recommend filtering the results down to the reliable Japanese brands - Panasonic, Nichicon, Rubycon, United Chemi-Con, Elna. And then work from there...
Higher voltage than what is already existing is rarely (almost never) a bad thing.
