fazer said:Whoops, like your work. Ive been listening this morning. Nice and organic but jazzy and laid back. Brave not going to verb syrup on everything. Nice.
On the pedal I have one more thought. If you break the connection into the blend pot from U5 pin7 at the pot it becomes an insert point and could be wired to a TRS jack like on a unbalanced mixer insert. You could then have TRS normal so if your not plug in T and R would connect and pedal is normal. If you want passive rolloff you plug jack with 10k pot and cap . If you want an active EQ you plug a TRS Y cord and plug eq or eq pedal in for tone. Just a thought.
Thank you so much, and thanks for the idea.
But I really just need something really simple, if it's simple and works thats fine, I dont need to try all the possibilities. Just want to be able to make it darker . Will try Abbey circuit next type I go to the shop
Thank you
