Rochey,Rochey said:Okay - MSP430 GPIO is connected through a current limiting resistor to an NPN transistor, emmiter to ground, collector to the bottom of a string of diodes.
Simple bitbang software on the MSP430 with a counter, that will do a rudimentary PWM.
/R
hey man
RISC micro-controller with a switching transistor opposed to a dedicated LED controller chip..
how much more components you need to run the MC, and also how stable it will be under a car voltage fluctuations
i am looking at costs here ,and also the more easy to assemble the better...
I mean , i know you are a whiz TI Microcontroller Coder , but... Ahem... Rolo is not... lol
so i dont know if you can take a peek at the LED driver chips that where already posted in here
or come up with a complete circuit and code to have 2 brightness levels on the LEDS
one for normal running level and when you press the brake pedal
also i want to have 2 pots, one for the idle level and one for the brake level
that way i can adjust the levels to an acceptable OEM escalade tail lights levels or at least close to it
thanks for your help Rochey
Rolo.
