[quote author="safe as milk"]hi re the input trafo-
6 ground
tie 3+4,2 hot in,5 cold in
tie 8+9,7 hot out,10 cold out
hope this helps
cheers[/quote]
guys, thanks for you patience and input!
Your description about the input transformer is the way that I had it wired, except i had pin 6 jumpered to 10, which were then wired to star ground. Now 6 goes to star ground, and pin 10 is the cold output.
Still no big difference in the output of this thing, I has about 6 gain settings that are different. ranging from very low gain to all the same higher gain but not overloading my Metric Halo Audio interface input (which is set to instrument level, and -10line works but is lower signal).
Here's the breakdown of what the switch does:
12-7= highest level output, all the same. Using the jumpered deck A and Deck B. All the same level out.
6=lower than 7 above
5=lower than 6 above
4=lower than 5 above
1-3 = barely signal have to turn the audio interface's input to +6db to hear anything, which is below -42db out.
Basically I'm not getting the obvious gain out of it that I'm used to with the N72.
Interesting though, when I put basses and kickdrums, any sound with energy below 300 Hz, and I get more obvious gains then a high-passed snare, loops, etc.. which don't seem to gain at all.
Example, I put a snare highpassed at 390Hz set to 0db output from my sound interface, and at the BA283's highest gain setting then got -0.3db to 0db back in. No gain.
I try this with a sub-bass or a kickdrum and woooah.. i have to turn the output way down, and these definately become gained and sound great. The swiches still do not offer many choices still though, as described above.
Am I missing something here with switch wiring, and/or has something gone bad that isn't obvious? It's really strange how it gains only sounds below 300Hz.
thanks in advance,
Jay
