Keith,
I'm sorry I'm trying to follow your discussion with rodabod about "virtual earth", but I must be too green in electronic ! :wink:
[quote author="SSLtech"]
Vertiges, -sounds like you have found the problem. -Yes, as I mentioned earlier, an un-referred input will cause the output to slew dramaticlaly to one rail or another.[/quote]
I've learn so much in the last 48 hours...
Adding a 'mute' link to the 'upper' end of the inout TX secondary will indeed mute the circuit, but it will also short the secondary of the input TX. -If you do this with a high signal present... -well... just
don't do it, that's all. :twisted: [/quote]
Ok, I won't. I've to confess, I was thinking about doing it because I'd like to have a mute on my preamp. But I will find another way !
You may have done something nasty to the core of the output transformer... I'll let others direct you as to what best to do.
[/quote]
:shock: I hope not !!!
I've put back the output TX and a 2520 in the circuit, I've added the wire to ground, and I've tested my preamp with a SM57 and headphones.
THE GOOD NEWS : It works quite well, I'm able to get a lot of gain ! The sound is not distorted, but I just have a lot of "static noise", but my chassis is not grounded yet and I'm plugged in a cheap little Alesis/wallmart_PSU mixer ! Just switching off the soldering iron reduce the noise by at least 20 dB !
What would be the symptoms if the output TX is damaged ? I mean in the point of view of the sound ?
THE BAD NEWS : one of my 2520 is dead !
eD
