Peter, the termination was SIX ohms, not sixty-eight...
The lack of a DC voltage reference caused the 2520's formidable output current drive to be brought to bear upon an unsuspecting transformer...
Yes.
eD, you don't need a scope to demag... a scope is a good tool for hunting and finding distortion, but it won't help you fix it... it just helps you to see WHEN it's fixed. -Of course I have access to a few distortion analysers here, so I'm spoiled rotten....
Personally I am always wary of DC-coupled transformer connections, and would NEVER connect one up without measuring the DC offset first, but of course I learned this a long time ago the way so many others did... by making the mistake.
Anyhow... it could be worse. -It could be a Porsche alloy V8 motor that you built, and you could have left a loose nut in, to tap-dance on a piston crown and bugger up the entire block... now THAT costs a lot of money!!! -(ask me, and I'll send you pictures!)
Transformer: I'd just take it to a twenty-pound (weight, not cost!) 2"-tape bulk eraser, switch it on and slowly bring it into the field, leave it there for an hour or so and then slowly take it out of the field. You'll be fine. -The dead 2520 will need a funeral, unless of course it's not potted, in which case it can be repaired... -I don't know the Petey-Purpose-like 2520s intimately... -I'd like to, however! :grin:
25K versus 20K... only about a dB's worth difference I suspect. On a log scale, the resistance has to accellerate dramatically for every dB's worth of change, so as long as it's reverse log, don't fret too much.
The effect on the signal would very likely be to 'bend' the signal towards one pole or the other. There would be no sharp steps like clipping, so no 'fizz'. There'd be no crossover distortion to speak of, so no 'crunch'... it's hard to hear, but it won't sound like a behringer... it just won't sound 'right'.
Anyway, you can pass signal and it doesn't irreversibly hurt anything to use a transformer with a magnetised core... it just sounds a bit funny.. perhaps 'vague' compared to a clean, punchy API in good health.
Keith
