helterbelter
No, in this case you don't have to use the 38 pin cable.
Basically, you have to :
-record a SMPTE signal on track 8 (I think the timepiece can function as smpte generator, otherwise you can use a smpte generator vst plugin)
-Connect the output of track 8 to the smpte input of the time piece, and connect the midi output of the time piece to the midiinput of your DAW (sync on, sync to MTC from midiport, etc)
-Of course you have to setup the synchronisation settings of your daw program. I guess the timepiece will function as SMPTE to MTC converter straight away, but maybe I'm wrong on that. Check the manual.
Then..... Hit the play button of your 48, and the daw should follow.
Which format of smpte to choose.... without using video, it doesn't really matter, as long as you use the same format throughout. I suggest that if you live in an NTSC country, choose 30 frames, if you live in a PAL country, choose 25 frames, etc, etc.
