Igor's high quality projects. Store closed, stuff shipped. A crazy idea - pg83.
Igor said:
Yap. This PS can power a pair of 1081's.
That part of the the reasoning behind  my purchase is exactly that it's for my 1081 builds :)
Only issue is you will have to do a little something something for the Phantom power, unless I've missed something. I was going to use a small board to the side for phantom myself.
Igor, sorry man if I started something...
Don't phantom yourself!!!!!! 48v not lethal, but harmfull :)
Hi Igor!!
Just ordered 4 N*ve Psu pcb , 10 DI/Phase/Pad boards!(added 6e for shipping.)
Hummm...48V , Kazper , hope you'll post your schem for us !!!! ;D
Cheers!!
Yes, IIRC I sent 2 or 3 Sontec kits to France at december...
PM me with your exact address, I will check this again.
Please pm me your shipping address to check for tracking Nr. etc.
Igor said:
Bypass PCB's for Purusha regular cases
(bypass boards which fits regular Neutrik
nc-3 connectors and can be used with all standard Purusha's cases,
60mm beetween Neutriks)
Btw. not every Purusha case has the same measurements there.
60mm: Dual 1176, M250P (for Igor's Equaliser I think, lost the overview), Night EQ
NOT 60mm: Dual Mic Amp, Mono 1176, Dual LA2A, GSSL (last three: 50 mm?)
Yes, I think it is better to take measures first :)
I using 2 standards of stereo back pannels from Tat,
one like used on Stereo Sontec and one like used on 33609.
Both fits bypass PCB's OK.
Hi Igor, I've looked at the PS PCB and it doesn't match with the one you gave schematics and BOM. Mine has room for a 783, more caps,more diodes... and the connector is 6 holes instead of 2*4 holes. For a newbie like me is it possible to use it and how?
Julien
OOPS... I think it is power supply for +/-24 and 48v phantom I using with pre-amps....
I did not packed EQ kits by myself, maybe it was swapped....
Anyway.
There's 2 options, I can send you power supply for Sontec (+/-24)
or just don't use 48v associated components, it will work 100%.
Please PM me your mail address for schematic etc.
Hi, there's some people received wrong power supply PCB's with Sontec kits.
I doing my best to resolve this.
Please check here:
http://www.groupdiy.com/index.php?topic=26599.360
Next time packing the kits I will double-check to avoid mine and yours headache.
