Rob Flinn
I think if you look at thecircuit you will notice that there is a connection to the centre tap of one of the transformers. This seems to be a potential stumbling block for your plans
In this schematic the T1 center tap is used for parallel connection of the secondaries or am I missing something?I think if you look at thecircuit you will notice that there is a connection to the centre tap of one of the transformers. This seems to be a potential stumbling block for your plans
In one of the manual the diodes are listed as FW matched (Forward voltage)
1N4153 are easier to match as the FW from each diode are closer to each other than 1N4148's
rob, do you have a working prototype waiting for diodes to get plugged in?
On IJR`s version he has 4 300pf caps across the diodes. Which there are only 2 100pf caps on the 33609 diagram
Do you think it would be worthwhile for me to start on a version IJRs boards, or just wait since there are several people already working on it?
The early 2252 that was rejected by BBC used 1000p across the diodes, the 2264 with BAX52 diodes didn't have these caps at all!
