No... I'm not sure how to answer without repeating myself. Modern interfaces are about maximizing signal voltage transfer, not maximum power transfer.Hmmm.... In "principal" wouldn't you want to transfer as much "power" (as opposed to voltage or current) as possible from the source to the next stage to preserve as much of the s/n ratio as possible at the final output? I realize that there are lots of other reasons not to do this. I am thinking of a giant tone arm/stylus playing a huge record with an output z of 8 ohms. Wouldn't you get a better s/n ratio by hooking it directly to an 8 ohm speaker than any kind of amp with a higher input impedance? ( Ignoring stylus loading and lots of other stuff).
Old school transformer I/O did indeed look for max power transfer (when source impedance and input impedance are equal.) Modern interfaces use what is called "bridging" terminations where input impedance is 10x or more the source impedance. (Not to be confused with bridged power amp outputs, something completely different).
PS; EIN (equivalent input noise ) is generally characterized as a noise voltage (or noise voltage and noise current) not a noise power. Best S/N is realized from most signal voltage vs least noise voltage.
