1) Is it advised to place the VU-meter directly across the output? There isn't any need for a buffer/driver to both drive and calibrate the VU-meter with to the signal?Hi Nate,
Here is a rough updated/cobbled together schematic that shows the layout I use. I want to preface I'm somewhat of a novice, so others may have better perspectives or tweaks to what I'm sharing.
The pot is a 250k linear pot. The bass control is on a 6 position make before break switch. I haven't implemented the high end/treble control as of yet. I found the bass and negative feedback control gave me what I was looking for. View attachment 125030
If I remember correct the pair that I built I found that with a 250k pot at full resistance it was almost the same as taking the loop out.I always have one position on the capacitor switch with no contact, so that the negative feedback is completely switched off. I like it, depending on the source.
1.) I don't always use a VU meter. If I do, I put it on a switch and have typically leveraged vintage style VU meters with an internal diode bridge. Adding a VU meter across the output without a buffer will introduce additional harmonic distortion, which can be good or bad depending on preference.1) Is it advised to place the VU-meter directly across the output? There isn't any need for a buffer/driver to both drive and calibrate the VU-meter with to the signal?
2) Which EDCOR transformers would you recommend for both T1 and T2?
3) Would all of the "Bass Control" capacitors also be 400VDC types?
4) A] What is the actual voltage on Pin-3 of V2? B] Why does V2 say " X2 "? Are there 2 of them? If so.....where?
>> A couple of weeks ago I received a package containing 50-pieces of 47uF @ 450VDC electrolytic capacitors!!! Now this circuit could give me a reason to use them in something!!! YAY!!!
>> THANKS!!! for the EDCOR "WSM" info. I personally like this style of the "same thing, only different" transformer:1.) I don't always use a VU meter. If I do, I put it on a switch and have typically leveraged vintage style VU meters with an internal diode bridge. Adding a VU meter across the output without a buffer will introduce additional harmonic distortion, which can be good or bad depending on preference.
2.) I've only ever used Edcor for the output position: WSM Series 15k - 600
3.) Yes and I typically use these capacitors: Mallory, 400V, 150s, Axial Lead
4.) A] I don't have the actually voltage measurements sorry -- B] There are not two of them, just one. Not sure why is has the X2 there.
Best of luck on the build!
>> I'll go for a VU-meter buffer/driver circuit that also has a calibration trimpot. That way.....I can inject an input reference signal and then adjust the meter for a "0 VU" reading to that reference. Have any suggestions???Putting a usual VU meter with 3K6 resistor across a 600 ohm output circuit (600 ohms source impedance) adds about 0.3% distortion if I remember correctly so you need a buffer circuit unless you want the distortion.
[Here's a meter buffer circuit that MCI used on their JH-24 tape deck meter bridge] -- THANKS!!! I appreciate it very much!!!Here's a meter buffer circuit that MCI used on their JH-24 tape deck meter bridge. I made a bunch of these to build a meter bridge for a mixer I have. The Collins tube circuitry won't have the +/- 18V supply that this uses though, so you'd need to add a small dual supply for these. To get more adjustment from the pot I replaced the 270 ohm resistor on the left end of the pot with 100 ohms. The board location drawing on the left shows holes where the meter screws pop through the circuit board to hold it on. You don't need the record and input status lamps shown at the bottom of the page of course, but you might consider running some voltage divider resistors to the meter housings for some lights in them. So as to not load my bus down so much, I doubled the two 2k ohm input resistors to 4k ohms. A good way to get rid of some of those uA741s that have been piling up in your spare parts drawer!
Here is the power transformer I typically use: https://www.hammfg.com/part/269GXHere's my take on the heater and B+ transformers:
>> 115/230 Primary -- 6.3VAC @ 3.2A Secondary
>> 115/230 Primary -- 230VAC CT @ 50mA Secondary
Any comments? Anyone??? Bueller? Bueller?? Bueller???
Hey Nate,The negative feedback adjust is pretty cool! It gets pretty beefy.... Great feature!
For the low end adjustment, I had a 4 position switch and put some random caps in... they are .022/.01/.0047/.0018. Seems the low end drops a little like a shelf with each different value. The larger the cap, the less low end. With the .0018 providing the greatest low end. Is this correct?
Nate
One call out on the Edcor step-up input transformer. It doesn't have any shielding, so it may introduce noise into the preamp and placement will be important. Typically, this is why I leverage more traditional new or vintage step-up input transformers that have additional shielding, which can be more pricey. I'll be interested to hear how it works for ya.>> THANKS!!! for the EDCOR "WSM" info. I personally like this style of the "same thing, only different" transformer:
https://edcorusa.com/products/mxl-series-1-2w-balanced-or-unbalanced-line-matching-transformers
And.....I like this style of EDCOR transformer for the input (200-Ohm : 50K):
https://edcorusa.com/products/umm-s...1&_fid=b7700780b&_ss=c&variant=42317234143481
[Adding a VU meter across the output without a buffer will introduce additional harmonic distortion] -- So, now I guess I need to find a good VU-meter buffer/driver circuit, huh???
[Yes and I typically use these capacitors: Mallory, 400V, 150s, Axial Lead] -- The capacitors that I bought are in a small -- radial -- package and were only $0.40 each.
[I don't have the actually voltage measurements sorry] -- Since I'm not a circuit-designer type of person, certain things easily confuse me when I'm looking at a schematic. Looking at "R7", it shows that there is 240VDC on one side of the resistor, but on the other side it is showing -- 2.84V RMS -- and connecting to V2/Pin-3, so that makes me wonder what the voltage rating of the "Bass Control" capacitors should be.
[There are not two of them, just one. Not sure why is has the X2 there] -- One of life's many mysteries, huh???
>> So.....were looking at: 1 - 6C5, 1 - 6J7 and 1 - 6X5.....right???
Going along within my "designing things a bit differently" philosophy.....I am not opposed to enclosing both of my PCB-mount power transformers within -- shielded enclosures -- as shown below. And, actually.....this is something that many others on this forum should also be doing.....anyway!!!It doesn't have any shielding, so it may introduce noise into the preamp and placement will be important. I'll be interested to hear how it works for ya.
