Ive just scrapped a little peavey vypyr with a funky dsp chip ,and Im left with a fine cabinet/speaker and chassis.
I have a set of transformers given to me years ago by the boss of the studio I used work in ,it was a kit of some sort I believe.
The mains tx is quite large for the original 2xEL84's and ecc83 based setup ,so I reckon I could possibly get away with 6v6's instead .
Im just wondering if the other amp-heads in here have any particular favourites in the 15-20 watt tube amp range,
the output transformer seems to be ultralinear tapped. I was thinking of having a series of switchable coupling caps at the input to the first grid as a bass cut filter, I know that wont give a steep cut-off but thats ok too ,maybe simple treble and mid controls between first and second(phase invertor) , just old fashioned clean to drive non master volume would be perfect. It'll be a tag strip point to point build .
Nothing is set in stone at this stage and Im open to all suggestions even slightly off the wall ones .
Thanks once again.
Thanks once again.
