This is found in an old Philips tube PA. Signal is shorted and negative bias voltage is adjusted by turning the pots. Current is indicated by a lamp. Another lamp is reference. When adj.lamp matches ref.lamp bias is set.
Hello Rafael! Yes its a cool system that makes it easy to bias. Function is described in attached file. Schematic is also there. One tube was redplating like hell until I found a shorted dc-block cap from the phaseinverter. But havent listened to it yet
Btw: Tomorrow At the Gates will be playing here in Umeå at House of Metal and I will be there!
