Is the Neumann W495B EQ DIYable?
[quote author="PRR"]Frankly, I suspect 5532 would work as well, a trace better, and a lot cheaper, but may not have that German Radio sound. [/quote]
All non diskret OP in the later Neumann stuff were build around 5532/5534
(Line amps/summing/EQ/etc.). So I think you will not have any problems with "removing" the "german radio sound".... :grin:
Thanks to you all....
Well, I think the project is still on then. Right now I'm looking for some second hand neumann stuff on evilbay. Even a simple stereo fader has 4 transformers in it, and much cheaper than @ Haufe....
Thats good news. Do you know this only about N*eumann or also about all the other Rundfunktechnik-brands?
radiance, we should stay connected that we don´t bid in the same auctions...
:grin:
cheers
Jens
[quote author="jensenmann"]
..... Do you know this only about N*eumann or also about all the other Rundfunktechnik-brands?
Jens[/quote]
Well, if it's a active fader it has transformers in it most of the time.
What I usually de when I see a neumann module is check the schematics on http://www.kubarth.de/cgi-bin/diy/german/index#u
