[email protected] said:I want to replace all the weak points of the machine
Is the PSU a weak point in the KT-2A?
+1Whoops said:Is the PSU a weak point in the KT-2A?
The main point here is that no significant improvement is to be expected from replacing the PSU.FarisElek said:But, building a linear PSU is getting to the point in which you should probably sell the Klark Teknik and spend the money you want to use for modifications to build a clone yourself with all the parts you most desire.
abbey road d enfer said:The main point here is that no significant improvement is to be expected from replacing the PSU.
Tosay, for a designer, using an smps instead of a linear is not a matter of cutting cost at the expense of any loss of performance, it's just the way to go, as long as certain precautions are taken.
In all honesty, I wouldn't be capable of designing an efficient smps, but good ones are commonly available and cheap.FarisElek said:Totally agree. I like Linear PSU's. But I don't think it's a flaw in this unit.
Ryan
dickiefunk said:I've just ordered some Harma tubes for my KT-2a. Still torn which optocell to get. I found another comparison of the Black Lion T4bla against the stock T4. Here is the link :-
https://drive.google.com/drive/folders/16_CwJ1MHZlQyyP4p5luIYNqrNVdOgg3p?usp=sharing
Which clip do you prefer?
Do you recommend another brand of polypropylene capacitor?
I do not know that.There's a lot of different brands of good polypropylene capacitors like WIMA, Panasonic, Vishay.
But the question is, does changing film capacitors gives any improvement?
I've got no real LA2A or high quality clone to compare to, but the modified KT is right up there with the best vari-mu, opto, VCA, FET and diode compressors I own. Even with the upgrades it is as inexpensive as DIY and all the mods can be done in half an hour (that includes cleaning the PCB around the signal path tubes from solder flux).So, buy a unit, swap the TB4 cell, get some nice tubes and ditch the big output cap and I will have a nice La2a ?
Could never DIY one at that pricepoint, case, transformers, knobs, meter, no way.. So these cheap clones may be a blessing after all ?
