How would one go about adding attack/release/ratio to this compressor?
Attack/release are determined by the optocoupler; it's almost impossible to modify it, even with a completerly different side-chain.How would one go about adding attack/release/ratio to this compressor?
Hey there. Longtime lurker, first time poster here. Just wanted to chime in and express some gratitude to you all for the super helpful information. Thank you! I added a Solen cap and Kenetek opto. I also swapped the Bugera 12ax7 for a newer Mullard which will do until I can hunt down some vintage RCA's. Will probably go grey plate for both the 12ax7 and the 12bh7. So far the unit sounds great. I'm very pleased and grateful to all the contributors in this thread. Happy New Year!
Makes me wander how in the world Tubetech did it with the CL1B. J Petersen must be a genius.When I was a kid, I gave this a lot of thought also: The characteristics of the LDRs are somewhat temperature dependent - I was thinking about adding a peltier cooling system, and thereby messing with timing. Never got around to it though, too much resistance from regular studio users at the time...
/Jakob E.
I think Kenetek sells a "fast" t4b. Still too slow?Naa, that was simple enough: running a much faster opto on rectified and timed DC - this is a very different concept. The hard part is to do timing on/within the T4B which is notoriously all-slow already
Ah ok, will do!The T4b is meant to be activated with simple AC - and the time constants are in the EL-panel and the photoresistor. It's a different beast than later designs - look at e.g. LA4 for a more modern take on the optocompressor
I simply fit it on the front of the PCB, there is enough space (did it successfully in 3 units).Dude...how in the WORLD did you get that 10uf 400v Solen cap to fit there...mine won't fit on neither the front or rear...I had to hot glue the capacitor on top fo the transformer and feed the leads to the holes with wires.
Ok ill give it another go.I simply fit it on the front of the PCB, there is enough space (did it successfully in 3 units).
Not the best idea. Transformer gets hot, capacitor lifespan decreases 10 years for each 10°C increase.Dude...how in the WORLD did you get that 10uf 400v Solen cap to fit there...mine won't fit on neither the front or rear...I had to hot glue the capacitor on top fo the transformer and feed the leads to the holes with wires.
Pretty much indistinguishable.Here is a vocal track i found dry and compressed with true LA-2A. So i matched GR as best as i could, and got some pretty amazing results. I found that original LA-2A saturates a bit more at high end, and even sounds a bit pointy at sibilant letters. Could be that output was driven a bit more.
Other than that, i would call these two almost identical. For about 300 bucks, KT-2A is a no brainer.
True LA-2A
https://app.box.com/s/yy41uru6jijn06m28ley0abnd780k313
Klark Teknik KT-2A
https://app.box.com/s/58m0aiqtap6jcjyhzklp2qoptr6yzgqf
Yeah I don't know how else to mount it. I tried again, even removed the pcb entirely and tried to fit behind like the other guy did, but it's just too thick.Not the best idea. Transformer gets hot, capacitor lifespan decreases 10 years for each 10°C increase.
I’m planning to mod my KT-2A cause I find it compressing the highs a bit to much even when the pot is set to flat.The red one at the bottom (22nf) and the two yellow ones above it (100 nf) are directly in the signal path. The two yellow ones next to your thumb are in the sidechain, no point in changing these IMO.
What pot?I’m planning to mod my KT-2A cause I find it compressing the highs a bit to much even when the pot is set to flat.
I don't see a C14, unless it's the 50-380pF trimmer near the Peak reduction control pot.To my understanding the C14 and C4 are responsible for the frequency response of the LA-2A and the side chain circuit.
Oh I mean the pot on the chassi, Pre-Emphasis.What pot?
Both C14 and C4 are trimmers, that are adjusted under test.
Since trimmers are expensive and induce extra labour, I would think that KT have replaced them with fixed values.
Did you find if those were it?Oh I mean the pot on the chassi, Pre-Emphasis.
I found a C14 but it’s a 1μF electrolytic so I don’t think the KT-2As components are labeled the same as on the LA-2A schematic but I’m not sure…
Yeah you’re probably right!
I found 3 ceramics which has,47pf and 2x 471pf.
Which is the closest caps I can find to match the LA-2As variable capacitor range.
