pvision
Info needed on Korg SDD-1000... Not the SDE-1000, SDD-3000 or other versions
It's an early DDL. Power transformer is U/S
I am looking for a schematic or details on the secondaries of the transformer, or a replacement transformer
Primary is 220 Volts
Transformer is a Bando SL 68-30 2. It is also marked BANDO TB-802 4BBE1
It has five wires from the secondary and the plug on the pcb is set out as 1 + 4. The psu has three regulators, +15, -15 and +5
I assume the transformer secondaries are ground, +15 & -15 (or thereabouts) then +8 (or thereabouts) with a separate ground
