Rybow
Good to hear that someone has made some progress on this thing.
rrs said:Yes ......
Not after files to make my own PCB that's not known to be working.
I think a project with some support like the GSSL's and 1176's is more so what many would go for.
Insomniaclown said:Any thoughts on the value of C16? Its the only part I don't have a value for in my BOM. Everything else is mapped out according to the waltzing bear schematic, JBL manual schematic, and the kenetek component layout sheet.
Rob Flinn said:Insomniaclown said:Any thoughts on the value of C16? Its the only part I don't have a value for in my BOM. Everything else is mapped out according to the waltzing bear schematic, JBL manual schematic, and the kenetek component layout sheet.
We could do with the help of someone with an original LA3a.
Rob Flinn said:rrs said:Yes ......
I'm just wondering how you think a project turns into one that is known working with all erratas solved & has a massive support thread ? It takes people taking chances on a project & contributing to threads.
The reaility is that these boards do work.
Insomnia
I cured the noise problem which was just a cooked transistor.
I still haven't worked out the level issue, mainly due to being very busy with work. I did check the board values against the diagram, but couldn't see any issues. It seems that the sidechain just isn't creating a big enough signal, since this pretty much just comes straight from the input. I have subbed in a Sowter transformer for the input & was suspecting that the ration may not be high enough. All the other transformers are proper spare parts so should be ok. I just need someone to check the ratio of an original for me.
I don't have the input pad fitted& I have the low noise mod done to the make up amp.
