Well, I was just writing this reply when you posted, hahaha....
so, here's what I have written in the meantime, even though I see much of it isn't apllicable anymore, haha :
Well, I thought about it for a while. Now I re-read your post I see that you couldn't calibrate it correctly either...
About the input sensitivity pot : Most of us don't need it, since you could vary the gain with the device you put in front. So, I remember that you said that you use a G9 as mic pre. I don't have one, but IIRC it has an outputcontrol. You could use this one for gaincontrol. Together with the gain switch it should be enough control.
But talking about distortion, could it be that the common mode trim is set wrongly ? You can apply some audio to the gainswitchpin that's in front of the 30k resistor. Set the threshold as high as possible, so the compression is off. Now you have just the lineamp of the LA4 that you hear. Distortion? * ? put the outputlevelpot a bit lower. Still distortion ? post again.
* : (In case you don't have distortion this way, apply the audio to the input, and check again. If there's distortion at this stage, then you know where it's at.)
Oh, and I'm guessing too, I'm an electronics starter as well.
