Today I tried a COMPLETELY different Input Transformer to see if the high roll off would go away & it did!!!
For the hell of it I tried these TAMURA 600:600 (1:1) instead of the EDCOR 10k:10k's.
NOTE: Don't pay attention to the LOW END BS going on, my main concern here is the HIGH END rolling off like it did with the EDCOR's on the input.
Here's a sweep of JUST the Tranny (Un-Loaded) just to show what IT looks like outside the circuit:
Here's a sweep going thru my LA2A. OUTPUT is Un-Balanced (No Tranny)
The Tamura is on the input & the Secondary is loaded with the same 10k.
Notice theres NO strange Bump in the low mids & NO EARLY HIGH ROLL OFF (starting around 700Hz or so)
Here's a repost of the EDCOR 10k:10k on the input & once again the output of the LA2A is Un-Balanced.
I don't know how some of you guys get these things to work correctly for input trannys in similar circuits... like ANALAG's Opto Comp, etc...? :?
Either you don't care what it looks like, your lucky, didn't actually sweep/TEST or I got a batch of strange or bad transformers which I doubt.
I hope all this BS helps someone... I'm ordering some JENSENS OR CINEMAG's for this LA2A ASAP.
