khstudio
[quote author="emrr"]An obvious thing that seems to have eluded us all. You are using the XSM series, which have worse response specs than the WSM series. I doubt you need the level handling ability of the XSM; even the WSM stuff has around 10db more headroom then the original UTC iron. Your response measurements with the XSM input are in spec. I'd try the WSM since you've already done so many comparisons.[/quote]
I Know... the only reason I bought these to use was from other guys using them on "similar" builds. + there cheap.
The input especially is VERY BIG compared to what is needed.
Right now I'm just running Un-Balanced input until I get my CINEMAG or JENSEN's in
I paralleled a 16uf across the 10uf to get a total of 26uf on the output CAP.
This brought that bump in the lows down.
UnBal-in - 26uf output Cap (C3) EDCORE XSM 10K:600- NO LOADING
UnBal-in - 26uf output Cap (C3) EDCORE XSM 10K:600- 600 Ohm LOAD!
UnBal-in - 26uf output Cap (C3) EDCORE XSM 10K:600- 600ohm Sec. & 11k LOAD Primary
