zamproject
- Joined
- May 11, 2010
- Messages
- 1,622
Hey
There is capacitive coupling involved in the system holding the sound attack/note-on trig, via the "boite d'attaque expressive" (expression attack box...another safety issue due to asbestos fibre in it, wish I will find substitute)
But for the understanding and (passive) measure I have now, the "corde" system is totally an on/off DC switch...from HT to 6BA6 G2)
There is DC capacitor discharge involved in the "percussive" network (around P switch) to aslo drive the pentode screen with keayboard dedicated switch but this is an alternative function decorrelated to the expressive box (drive grid via lower A switch assembly), which again differ to the "percussion" setup
If my math are good, we have 0.3mA here, which under 140v is 40mW.
Theoretically no issue for human body, but what if there is a fault (short resistance ?) or anything on the HT.
Not to mention the original wiring don't have safety earth ;D
If it's confirmed, I can't let this configuration wired and operational for future user...
IIRC the actual safety rules state that over 50V its considered "HT" and absolutely no part can be accessible by human, whatever power or amperage involved.
Best
Zam
radardoug said:You definitely should not be able to touch a wire with 140 volts on it! That will hurt! Are you sure its not some sort of capacitor arrangement? So the wire will be insulated, but press up against the other wire to change capacitance?
Best
Zam
