zamproject
- Joined
- May 11, 2010
- Messages
- 1,513
yes, I check this 3 weeks ago, have some read, and still don't know if I have to ground it.The schematic doesn't show the output transformer secondary is grounded
I'll measure tomorrow what's the peak to peak at speaker, and see what's requested to not fry my AD input...
Regarding hum ,"virtual" ground at heaters can be an option, but I have to check closely the whole ground wire.
Basically the ref wire (solid coper) run soldered at each frame all around, I see it like a ground plane using the 3 chassis...
I add an earth at main input (for safety), at the PSU/AMP section I post schemo today.
Then an umbilical go to the oscillator section (7 tubes, OSC/filter/tremolo/subOsc) with only 3 wire, AC heater (2wire) and B+
Then a second umbilical (from OSC section/frame) go to the keyboard and oscillator fine tuning capacitor at the upper section of the cabinet. There is a global pot volume (knee activated) which weeper go back (shielded cable) to the first block (PSU/AMP) and that's the only ground return to the first block for the whole "machine"
So the heater is floating in the upper oscillator frame (only referenced via umbilical to the grounded trafo 6.3 secondary at first block)
And all ground come back to the AMP via input banana jack
Best
Zam
