thanks for the answers,
regarding current draw both supplies are for 8 1272 type mic/line amps
well I wired the supplies in and connected it all up how I thought it would work and smoked the large 2200uf cap on the 24V supply
I've discovered this was from trying to create a common ground wiring both 0v from each circuit together
Is there a way I can do this?
The power inputs on the preamps have only 3 points 0v 24v and 48v
It doesn't make sense to need two separate 0v points
Checked both circuits for shorts and they both work fine independently and put out the correct voltages
If I leave the 0v on the 48v supply 'hanging' and try to use the 0v from the 24v supply to get 48v this way then I end up with around 26v :-\
Perhaps I've missed something?
