theaterguy
Active member
Hey, could you please put here the final schema. I'd like to build only the 48V side.
The configuration that has been finally adopted is not the most efficient for a single 48V rail. If you have the choice of xfmr, you'd better use a 48Vac xfmr, bridge rectifier and single smoothing cap. But if you already have a 24V xfmr, you'd have to use the standard doubler configuration (two diodes, two caps).theaterguy said:Hey, could you please put here the final schema. I'd like to build only the 48V side.
