Hello
I've been trying to build a 48v supply for phantom using a modified 24v lm317 based circuit board. Schematic #1 below.
The 48v circuit is based around schematic #2 below
To create the voltage doubler I replaced the D2 and D3 (schematic #1) with 2 1000uf 63v capacitors as I do not have any 470uf 50v caps at hand
I was also unsure of the 'series resistor' on the 317 input value (schematic #2) as this is not stated so used 68R 1W as saw another diagram somewhere (cant remember where ) using a 47r 1W
Also cut the track on the cct board between D4 and the input of the LM317 and soldered the resistor here
Added diode accross 317 in/out
Omitted C4 and C1 from the original
Used the 4k7 trim pot instead of 10k
Also there is a 1000uf 63v across the output replacing the 330uf 63v (schematic #2)
Here is the problems I have -
The circuit puts out 70v DC
The 4k7 pot has been smoked
Any fixed value resistor put in place of the pot also starts smoking
The voltage doubler is putting out around 70v DC before it gets to the lm317 :-\
why would it give 70v DC when the transformer is only putting out 27v AC
Are my oversized capacitors causing issue?
And would this smoke the pot?
This is causing much frustration as it should be a simple circuit and is the last thing standing between me and pumping 48v to any mics attached to these beauties :-[
Any help appreciated 8)
