moamps
ohm said:Are you saying that the - of DB2 should not connect the + DB1 and instead go to ground?
Yes,
look into schematic from JLM site you already posted.
In that case, the unregulated voltage will be insufficient - not a doubler anymore.moamps said:ohm said:hmm voltage on + of C8 is around 71
Connect - pin from the rectifier bridge DB2 to the ground and recheck voltage.
Alternatively, you could connect negative of C8 to positive of C3.ohm said:hmm voltage on + of C8 is around 71
Looks like I need higher rated capacitor than current 63v?
abbey road d enfer said:Alternatively, you could connect negative of C8 to positive of C3.
Yes, but voltage across it (i.e. between pos and neg lug) is reduced by half.ohm said:Still I get 71v at positive of C8
ohm said:Shall I put 100k in parallel with C8 then?
moamps said:Use your law
abbey road d enfer said:Yes, but voltage across it (i.e. between pos and neg lug) is reduced by half.
tubegeek said:After a second look, I notice that the combination of R1 and R2 will bleed the charge from the 48V supply, and the combination of R3 and R4 will bleed the other supply. So no need for any additional resistors.
moamps is right, it is a nice law you've got there, by the way, thanks for that one!
What do you think?ohm said:Yes it is 36v
So this PSU is ok then? 8)
Good!ohm said:I believe it is. It spits out 24v and 48v and there is 36v across the +/- of C8
AND it hasn't started that filthy habit of smoking again...
We'll see properly once it's powering the preamps
