BertBert37
Member
I own a number of B-5s which work well. However 2 of them show low output - obviously due to low capsule voltage supply. In order to check the built in oscillator circuit I need a pertinent schematic.
Hi Jan
Again thank you for the pain to evaluate a complete and well structured reverse engineered schematic.
Uhmm, no 100nF... Well noted, thanks! Actually, that C12 capacitor should be C5. There are more errors, which I will discuss in another post.C12 = 10 nF? Really?
Thanks for reviewing the schematic, Bert. Despite all the checks I made, I made some mistakes. I'll go through them one by one and I'll adjust the schematic and PCBA picture accordingly.Hi Jan
Again thank you for the pain to evaluate a complete and well structured reverse engineered schematic. I appreciate this help very much. As stated before, I will resume the work with my faulty B-5 only in fall or winter. So far I have only a few remarks:
Bert
- I could not find R3, R9, C5, and C9 on the schematic nor on the picture. R5 exists twice, but I assume the one with 6k8 might rather be R9 connected to R11 ? C5 is only visible on the picture, but might be across C4 ? If C9 exists it might be 15 nF across C10 ?
- There are also some obscure details found in the schematic that have to be checked and give a chance for improvement:
- The signal path by C12 (10nF) and R5 (150k) form a high pass with edge frequency of approx. 100 Hz. This is against a good low frequency behavior !
- The output stage seems to be similar to a one sided schoeps stage. However the schoeps circuit uses the feed resistors (6.8k) in the phantom circuit as emitter resistors and provides a large output swing capability. The current schematic has a complicated network consisting of R1, R4, and C4 that lowers the available voltage swing and provides some low frequency boost near 150 Hz which counteracts to the above mentioned high pass. This is hard to understand.
- R2, C1, and C3 care for symmetrical load of phantom power and silence on the XLR-2 signal line. However it causes signal loss on XLR3.
- The 10 dB pad uses a voltage divider in the source circuit. This only reduces the level to the output stage, but does not care for lower distorsion in the input FET stage. A better solution would be to parallel the capsule by a specified capacitor. This would also reduce noise.
/Your proposed mod of the output stage makes sense. It improves the dynamic range and gets rid of the elcaps in the output which ruin low-frequency CMRR as they never have exactly the same ESR and capacity. See the CMRR plot of the B-5 which I shared in another thread. Actually, with this mod, you are just a Drain resistor and coupling capacitor away from a basic Schoeps-like circuit... OK, OK, the Pad and HPF circuits will become more complex too, but you're almost there.
With respect to load capacitance induced capsule distortion, there was thread on GroupDIY: How does condenser mic capsule load affect THD?
Actually, I'm also interested in measuring the real distortion's increase or decrease with a capacitive pad versus different capsule bias voltages. But I haven't made the setup yet to measure mic distortions. I want to measure mic distortions using two tweeters and then do a difference tone measurement. This is a well known method that eliminates the need for an ultra-low distortion speaker. But as I always tend to have more plans and ideas than time to materialize them, don't expect these measurement results anytime soon.
Regarding PSpice: why not use free LTspice?
Jan
