Looking for someone who can restorate a Sony C-48 in Europe
thewotan
Active member
Hello there! I hope this is not the wrong part of the forum to ask this.
I inherited a Sony C48 which is faulty. It cuts sound intermitently, and it also has cracks and pops sometimes. After opening it it seems like a general mess inside, and one of the diaphragms is busted (which I suppose is the origin of the fault). Seriously, it looks like the mic did something bad to the "tech" who worked on it. I hate it.
I would like to know if there is anybody in Europe who has experience working on this mic. It is my understanding that reskinning the diaphragm would not get it to original condition... If that's the case, and the only possible way to restorate it would be with a new C48 diaphragm (which would be impossible hard to get), could the bad diaphragm be disconnected and configure the mic as only cardioid?. Right now, setting it in cardioid with the polarity pattern switch doesn't make the problems go away.
It's incredible, but sometimes it works. And it sounds wonderfull. But it doesn't take long before it starts going bad. I would really like to get this working, but I know it is out of my repair skills.
Some pictures of the crime:
    1.5 MB
    1.2 MB
    705 KB
    722.7 KB
    1.2 MB
    4.1 MB
    1.2 MB
    1.2 MB
Who ever told you that stop listening to them! I am sorry for the tone. Of course it is possible, it is just important to find the right person to do it. I have worked on these mics successfully, however i am busy at the time and don't have the time to offer you help. I have measured fully operating originals, and i can say they are unique and marvelous mics. From what i can tell the capsule is the same as c800G. So good luck finding original replacement.
They are nothing like u87 (k64, k87) capsules so whatever you do, don't use anything but original capsules in this mic. The magic of c800G and your mic comes from unique backplates, not the diaphragm itself!
This mic is a u87 with c800g capsule in a nutshell. I would use it over u87 all day long!
Have you checked the tantals and electrolyts in the circuit. As it sometimes works shortly, the capsule seems to work actually at least sometimes properly.
Maybe worth looking in the caps first. They are easy and cheap to replace … but of course it’s a vintage - so you alter it.
Maybe measurements could help. Check the voltages and if they drop around the jfet obce it goes bad.
Hope it’s not the capsule, that would be a pity ;-)
Looking at the pictures I'm amazed at the awful soldering job. I'm assuming this isn't how it left the factory. I think a reflow of some suspicious looking joints couldn't hurt. Would be in line with the symptoms you describe.
That's good to hear! I don't remember where I read about reskinning not being able to restore the capsule to original condition. Glad to know that's not the case!
It is a wonderful mic indeed. Sounds better than a u87 to me. I've managed to use it to record some acoustic guitars and it sounded like a record with no processing whatsoever.
I'm not really in a hurry to get the diaphragm restored. Would you be up to it whenever you have more free time?
Really awful. No way this is how it left the factory. You are right, reflowing it wouldn't hurt. And I don't think I could do it worst😅
No, I haven't! It wouldn't hurt to check the caps, as well as reflowing the PCB. To be fair, I assumed it was the diaphragm because the issue reminds me of another mic I had ages ago with a bad diaphragm. But I suppose a bad cap could also describe the symptoms.
Many thanks to everyone for your assistance!
hope your capsule is still working on the „untreated“ diaphragm. if it‘s just a cap or connection you may still have a really nice mic for cardioid only.
fingers crossed ;-)
I'm fairly sure that I saw Andreas Stenzel sending off a C800G capsule to Rico Vetterlein. Maybe he'd also be happy to work on your C48 (and presumably Rico would be happy to do this capsule as well).
