Hey
@Khron , it's always nice to have you on board.
Microphone in question is Advance Audio CM67se or SYT-5 with modified circuit, so it's standards CCDA circuit with 9 polar patterns just like most Chinese tube mics.
Issue I have is when mic is in cardioid it works just like figure of 8, going further to omni mic looses all bass response 600Hz and down, when in figure of 8 no difference from cardioid both capsules are working.
There is differece in voicing in between front and back capsule just like in most dual diaphragm capsule. Ofaxis rejection is great and omni is well omni.
Maybe I messed up something ? In speck it says that it's design to run on 65-70v bias charge, I'm running it on around 60V. As well I assume ground wire from capsule has to be connected in all multi pattern mics?
Technical parameter:
Model m7
Sensitivity: -36dB ± 2dB
Pointing, multi pointing
Diaphragm transparency 25%
Overall dimensions: φ 32mm*6mm
Imported diaphragm: 6 micron polyester gold plated,
Frequency response: 20Hz~20KHz
Polarization voltage, 65-70
Power supply voltage: 48V
Capacitance: 70pf
