Tim Campbell
Yes Stephen and I became friends via the internet for the last years before he died and had quite a few interesting discussions.
This will work if quality isn't of any importance. A properly manufactured capsule can be mirror smooth without causing attraction. Even when Neumann placed bumps onto the surface of their K67 capsule it could still collapse when working improperly. High spots, contamination or too low a tuning tension for the membrane compared to polarization voltage are the most common cause of collapse. Roughness is used as an attempt to help the membrane release once it has hit the backplate.
Many chinese capsule backplates are highly polished without problem.
rulesI don't spend much time posting on here or RGO these days, but one thing I always see is Tim chiming in to anything Eric has to say.
Tim you're like a little girl. I'm so sick of your "fight" you keep perpetuating with Eric. Go do something else.
End of rant
BE NICEEthan said:4. You will find that the members of this community are courteous and respectful of each other, so please reciprocate those gestures. Leave the flame-war mentality at another forum. Personal attacks and generally hateful comments (regarding race, religion, gender, sex, etc...) will not be tolerated.
I don't think there's any accuracy in that, don't you think?
It seems they just stretch the membrane and go with it, I thought the process was a bit more precise and involved a measuring jig to measure the correct tension
Who is this directed at, is there anything we can do better?Yanking my chain over this is not a good idea...
Wave is Dave Wheeler who works for Heiserman Audio. I am unsure if this breaks the rules here but it is a bit sexist.I don't spend much time posting on here or RGO these days, but one thing I always see is Tim chiming in to anything Eric has to say.
End of rant
Tim,Neumann beadblasts their capsules as part of their deburring process.
I hope Marik joins in to reiterate his feelings about backplate flatness. Sound quality is not the only factor to consider here. Mechanical integrity is equally important. An uneven backplate will contribute to a membrane collapsing to a greater degree than a polished backplate.
