steppenwolf
Hi Guys!
I tried to move around some wires, put out the 47pF Cap, but that doesn't really change a thing.
Then I tried to disconnect the NF and putted in a alligator clip wire. Then I took the wire and moved it around the chassis, and that changed the sine considerably...That brings me to the idea, that it could be some canceling out somewhere.
The wires from the PI to the grids of the KT66 are inside a shielded cable.
Could that be a problem. They are really close and parallel in there and they are out of phase...Moreover there a are pretty high voltages passing through there. That could explain, why it occurs only on higher frequencies, as those are more prone to cancelling out I think. It starts to develop that ugly notch just as the sine begins to cut off maybe because distortion causes overtones...
What do you guys think about that?
I tried to monitor the B+. It is around 435V at idle and about 390V a full throttle, it gradually decreases with the volume going up...
Thanks, Stefan
No, it was around 90 Ohms to 70 Ohms, so that should be fine! Primary Raa reads 7600 Ohms, should have 8k, so it should be allright!If you are measuting 900 ohms from one leg and 70 ohms from the other then there is something wrong. Also these two readings should add up to equal the total resistance between the two legs (was this 1600 ohms?)
That does look strange, some crossover notch, but also some breaking thru at the very peaks. Maybe a layout problem, it does kinda look like positive feedback, but if you swapped the wires and it squeals then definitely not at the OT. You could try to move some of the power tube grid wires or PS plate wires, feedback wire from speaker, even back as far as the tone stack output....keep going back and reposition wires and see if anything changes. Or try a 12at7 and see if it gets better or worse, or load the secondary down 1/2 and see what happens to it, or disconnect the 47 pF, see it it clears up.....try and find something that affects it.
I'm thinking power supply...
Have you tried to monitor the B+ DC voltage while increasing the volume? How much does it sag?
Did you check the rectifier tube?
Are you getting full wave rectification i.e. ripple freqency at B+ should be 120Hz. Does it look on the scope like a nice sawtooth wave?
If your rectifier is bad it could be that you're not getting enough DC current out of power supply once the power tubes start pulling more than bias current.
Thanks, Stefan
