Ok. Anyone have any theory on how I might bypass the tube-makeup and transformer output stage of a Massive Passive? Sorta like the new Mini Massive, except I don't necessarily care about using the "Rapture" output amps.
As I understand it, the EQ is a parallel design. So I assume there are two tube stages, a summing stage to "mix" the individually eq'd bands together and an output driver.
I'd be fine with leaving the tube summing amp as-is, and just replace the output amps with a solid state solution.
Thoughts anyone? Perhaps someone has done some digging inside one of these and might be able to shed some light on the feasibilty of something like this.
Chris
Chris
