I think Keef knows of a mic that will take an exaust manifold alright.
Thanks for all the help Paul! I need it. I am mixing two schematics, which is a bad idea for a proto attempt.
The original schemo I have Does use a 10K resistor under the trans-diode in the current source. Now that I have this thing running, I can play with values.
The breathing thing may have had to do with the amp being in oscilation.
Did not do it the second time I tried it.
I will try messing with R4,5. In the app notes version, they sit on top of the emitters in the current source. Maybe this is throwing things off.
Everybody, including myself, misses R10 tucked inside the lower box formed by Q1-Q2 collectors. Badly drawn schenmatic. I think these 2N3906 transistors would saturate if I used 10K base resistors. Plus, I think one aim of having the 100K bias resistors is to keep the input impedance high, although there are still the phantom resistors...
I will try to match the current thru the transistors to the original values and see where that puts my voltages. Not a lot of headroom needed in a first stage of a mic pre.
I dropped the 3.3M feedbacks to 1.78M. This helped opamp oscillation. I don't need the full 70db of gain anyway. I have a V76 if I want to listen to the grass growing. I put in a couple of 390pf across the feedback resistors. Hopefully this won't chop much high end off. It seems to help improve phase shift.
I have to study the effects of paralleling transistors. I do not know of any books that cover this array concept.
The offset voltage of 22 mv was actually an error on my part. I was measuring offset with respect to the pwr supply ground. Since I am using kind of a instrumentation amp setup on the opamps, I should have measured from plus to minus output, as this is in balanced out mode, not single ended. When I wen back and measured from output pin to output pin, I read about 1 mv (still high by todays standards) on the B/B 2134. But the BB drags 4 ma, so maybe thats why. An analog devices SSM2275 gave me 50 uV offset. (now that's more like it).
The BB is a fet front end, so I think it will work as good as an 072, but I have a socket so I will try the 072 also, as it is the original for this circuit.
Ok, I have this thing racked, so time to try it out.
It's as light as a feather (ext. pwr sup).
I am going to make another one for field recording. I bet Lomax would have loved to have something like this back in his day.
see ya!
cj
