squarewave said:That all sounds good but you need to get rid of the thermals. Thermals are the little spokes around each hole for a part that connect to the trace / plane. The help you solder. Without thermals all of that copper wicks away the heat of your soldering iron and prevents the solder from flowing into the joint properly. But in this case you really need that copper. It doesn't really matter if you have giant traces if they then turn into 4 little spokes to get to the bus wire of the part. That's like making a 4 lane interstate highway that turns into a bicycle path for 100 feet. So I would dig around in your layout software and figure out how to turn those off. It will make them hard to solder. If the solder doesn't flow into the joint properly, you will need to get a bigger soldering iron. Usually people have one cheapo thing from the 80's that's like 50 watts just for this sort of thing. But a flux pen and some patients might also be good enough.
Although, is there no way to lay all of the SMPS out flat? Or at least the two 17V and then put the 48V over the 12V. You can put them right up against the edge of the enclosure no problem. And the PCB can be mounted anywhere. Maybe make it long and narrow so that it can be mounted vertically would help?
Great! Thanks. Thought I had removed thermals need to do more digging in Kicad been a while.
Will see what I can do regarding layout should be able to the get larger modules to layout flat.
Thanks again
Blissy
