This is really important! It's amazing how much influence the alignment of inductors has on the noise floor. There's something to learn here, just like with your experiments on the subject of the distance between signal-transformers and mains-transformers.The transformer's radiation/pick-up pattern should be at right angles to other sources to avoid induction from other transformers.
For example, I don't want inductive feedback from the chokes to get back to the inputs.
Hey Dave,The other side of the power supply box is now finished. It supports one end of the tube base deck and on the other side all the smoothing caps.
This is roughly how the caps will be fitted. The earth busbar will go through without touching and the HT/B+ will enter by suitable grommets.
I will fit all the power supply components before fitting the chassis together.
best
No, they are cap clips you can get from RS, (Farnell/Newark stopped selling them for reasons best known to themselves)Hey are those plastic pipe clamps holding your power supply caps?
You may also want to check these "battery/capacitor" clips out as well:No, they are cap clips you can get from RS, (Farnell/Newark stopped selling them for reasons best known to themselves)
https://uk.rs-online.com/web/p/capacitors-accessories/1025482
best
Thanks, I am familiar with the metal ones - I had not seen plastic. I still learn something new every day. Love it.No, they are cap clips you can get from RS, (Farnell/Newark stopped selling them for reasons best known to themselves)
best
I also admire his metalwork. That has always been my weakest point. So far I've also sawn everything by hand, but I've now upgraded. A 19€ hand-held mini circular saw (exklusive the battery), which I've also retrofitted with a metal saw blade. Plus a DIY saw jig to make better straight cuts in sheet metal. Here we go...Dave,
I'm amazed by your metal work, so neat.
This is the area where I struggle in my builds: Nice clean metal work.
Well done Sir. Hats off !
Wow! € 19 !!! Looks perfect, thats the way to go! I want one now!!!I also admire his metalwork. That has always been my weakest point. So far I've also sawn everything by hand, but I've now upgraded. A 19€ hand-held circular saw (exklusive the battery), which I've also retrofitted with a metal saw blade. Plus a DIY saw jig to make better straight cuts in sheet metal. Here we go...
It was a special offer at LIDL last week, now it costs 42€ again without battery. I'm sure there's better, but it's more than adequate for my purposes, a real step forward. I also use it to saw PCBs, fiberglass turret-boards and wood, it's really flexible.Wow! € 19 !!! Looks perfect, thats the way to go! I want one now!!!
Yes, I've actually drilled into the top of the washing machine before, no joke. I have so little space in my apartment, every free surface is used.Be careful not to saw off the domestic appliance underneath (Like in those old Benny Hill shows)
