Dave I admire your metalwork.Rock, you must be single, you have drilled into the washing machine and nobody has killed you!!
best
You're right, I'm single and live in an attic apartment. My workshop for bigger things is in the basement of the house, four floors down, and because I'm lazy, I use my washing machine in the bathroom for such things and avoid the stairs.Rock, you must be single, you have drilled into the washing machine and nobody has killed you!!
best
Especially during World War 2!!!British craftsmanship at its best! Long live the British workman, you can always rely on them
Like everything else, there are good and bad examples. Our plumber, for instance, is absolutely great - very clever guy, definitely wasted as a plumber but his problem solving skills are first class.British craftsmanship at its best! Long live the British workman, you can always rely on them
The output from the bus is likely to be high so the input transformers are 15k:15k. The output transformers are 15k:600.what are the values for the in-and output transformers and the control voltage as mentioned in the schematic?
Could it also be possible to use it unbalanced, with the output as a cathode follower?
Two of them are twin tubesDoesn't you compressor use 8 tubes?
If you read from the begining you will discover that the side-chain (6DT8's) are common to both channels.6 active stages of 6DT8 is 4 tubes. 2 EF83 and 2 E83F is eight, Am I just being stupid?
