MAN.... My congrats!!! You're fast!!!!ok, the R4 3k74 was the cause of limiting now the unit work nice
related problems:
- on ratio 2 the point of vu meter come to 8, cause of the diode D8 (for 4000 mode) D7 ( for gsll mode)in bad direction
- R34 & R40 burn the TL074 IC7 is in bad direction, change the resistor and the TL074
- SWITCH 3pdt on off on seems don't work, jsut link the three points ratings of the switch
In other words:
Check carefully if there's no components placed wrong. Check all resistor values.
Thanx again to Stereokillah, why not Sherlock Holmes?
I corrected 3rd post of this thread, BOM is right;
Put solder joint to pads near the 3pdt switch;
Thanx to 10R resistors, they acts as fuses if op-amp placed in wrong direction
Another thing. Regarding this thread:
http://www.groupdiy.com/index.php?topic=39897
Be careful when placing the unit inside 51x rack not to short power supply rails.
It is really hard to do: I tested MixBuzz500 in both 51X and Lunchbox racks),
but...who knows, everything possible.
For future, I will do all my 500/51x stuff with "slotted" connector.
