..but what is the deal with VCA replacement boards? Is there a thread somewhere I'm missing?
Original 4000' deck compressor used DBX202 VCA. There are many mods of 202, please download docs
(link at first page of this thread) and read. This is "homework"
After homework, soldering will go easier, have a fun!
It seems to me that I can either use the DBX or build a VCA replacement board. How do I know what the sonic difference is and is it possible to build the VCA replacement boards and swap them in and out to see what I like the most?
DBX202C should have its own character. I believe it should. But, never tried
The rest of 202's is pretty same : pre-THAT era VCA's with almost same pinout llike 2181/2151,
paralleled in eights or quartets. More or less distortion, more or less CV breakthrough,
this or that values for input/feedback resistors, sometimes, different control port impedances.
Maybe there are other discrete versions. AFAIK, 200 wasn't used in 4000 series compressors.
I don't pretend to be last instance for this info in any case
If somebody have more info to share, wellcome!!!
Replacement board: more or less DBX202R, IIRC.
Using 8 of THAT2181A VCA's is true overkill; have no any benefit IMHO
neither distortion nor headroom-wise.
However, quartet sounds really good. Very clean, but adds tiny bit of second harmonic if bit
misadjusted. For all guys who love "more sound", one 2181C is the option.
Explained some posts ago.
Another question. Is there any reason to use a better Quad Op-AMp then a standard TL074. If so are there any simple solutions for that? I see there is a TLO74/AD713 on the photos (my boards are not here yet). Is the AD713 a direct upgrade? Also which one do I want? I see a huge price difference between them (link below). Also, sonically what can one expect from the upgrade. If its a direct plug I can just test them out once built easy enough.
No, really, 074 is not in audio. It doesn't matter at all.
Why I used AD713, because I have some tens left, bought about 100 from surplus store for $2.
It is really cheaper for me than buy TL074 at electronics store for $1.25
But, AD713 opamp is fast and have very good DC characteristics (low offset).
If you can get them for cheap, use in every possible compressor's etc control circuit.
Audio op-amp is IC11. NE5532, OPA2604 is good choice.
OPA275 will not be the best here as it has relatively high offset and should work with low impedances
to reach its performance curves.
My last opamp affair was LME49710. Really, cool.
In MixBuzz500 we need dual op-amp.
Maybe, worthy to try LM4562.
One thing. OPA2604 has excellent DC performance (low offset) and very fast.
IMHO, this is excellent choice.
