martthie_08
ok, the mic build is completed for now, moving on to the psu:
I am using the collective cases psu with Binder connector, the recommended part number is # 09 0044 00 07 which is available from Conrad as catalog number 739030 (€20,99)
As this is a 7 pin connector it got me thinking if I would be possible to find an equivalent 6-pin Binder connector, like the supplied connector from Max, but it seems they are only available as 5 or 7 pin versions. Too bad, because the 6 pin versions are a lot cheaper...
anyways, the 7 pin cable plug is also available from Conrad as catalog number 739006 (€28,99). Not meaning to promote this company
but maybe this info helps other builders...
