Hello everyone!
I'm Alex and month ago I got the Mk47 kit from Ioaudio, today i did a first run.
I just moved to London so I have no tools aside soldering iron and drill, and I'm also poor so i tried to save a bit on not critical parts!
For example replacing the PSU circuit using the original little case that came with the mic PSU. But that was more pain in the """ than money saving.
At the first run i noticed couple of pops that disappeared 1 minute later. I used some used matched pair of 6028 that I slammed on the wooden floor while trying to unplug them.
I can't notice any difference in noise floor with the microphone either unplugged or plugged with lots of gain
. that's cool!
The original PSU came with a metal divider that was splitting the case in two. I used it as cooling sink for the 10W resistors and to separate the first ripply part of the circuit (diodes and first cap) from the second (all the rest after choke). Each part had own ground wire that was going to one spot.
The output voltage went to 350v when load-free, but 110v on load. I couldn't get down to 105v if I was on omni mode.
The mic is built in a Tbone SCT700 body. Instead of screwing the 5W resistor to the case I have applied some termal paste under it, and then while pressing it down I "epoxied" the two sides to keep it there. forever.
It sounds nice even with the stock chinese capsule, but I'm waiting for a RK-47 from microphone-parts.com
PSU inside (was actually small.)
If you were looking for the transformer and the choke:
[img=http://s7.postimg.org/t0n9dphuf/IMG_0214.jpg]
Heater dropper fix:
[img=http://s15.postimg.org/4bp5vftd3/IMG_0180.jpg]
Thanks Ioaudio and Chunger for parts and super detailed build tutorials. I once was dreaming of being 21 and rock star, but now I'm happy enough just building tube condenser mics
YO.
