useme2305 said:the test load gets you in the ballpark voltage so you do not damage the mic. readjust the voltage with the mic after the test load adjustment.
useme2305 said:don't you have the 5W pot in series with the resistors? if so, just get a 330ohms to replace the 680ohms resistor and lower the resistance of the pot by turning it. this will get you in the right ballpark with enough play for the pot.
EvLoutonian said:Oh, that's interesting..
Maybe I should simply disconnect the LED's altogether..
I did notice, so far, my mic does have a slight background hiss, where-as others here describe their build as positively silent!
(which is obviously what we'd all love to achieve)
Could the LED wiring really cause such noise/interference?
