ioaudio
I think it's ok - i probably have seen a build with it? Not quite sure atm, better check the dimensions.
Winetree said:Tried the 1950's Miniwatt gold pin "D " getters.
Didn't like them.
Yes, only compared them to new JAN 6028s.Were those TS62s, too, or another type?
And what did you not like about them?
Winetree said:Yes, only compared them to new JAN 6028s.Were those TS62s, too, or another type?
They sounded more lo-fi, smaller, different tone, unlike what a U-47 should sound like.
Just my opinion.
tfp said:Hi Max (sorry for Andreas I mixed something completely up),
I finished your beautiful project one month ago and the mic worked great with the standaard Philips Jan 6028 tubes, Thiersch red line and Ami body . The mike sounded great but with a voice-over recording it needed some serious low cut. I decided to change the tubes with two 1957 WE 408a tubes. I also changed the height (higher) of the capsule with 6mm so it is as high as the original U47.
Now the strange part, I tested the mic today and it sounded almost the same(did analyse signals), but below the 90Hz there is about -10dB less bass so the sound is more mid focused.
My question: Is this possible with changing tubes and/or changing the capsule height? Or do I damaged something in the proces? For example last night the wire of the backplate was broken and I kept microphone on for quite a time!
Thanks for answering!
RJ
adrian said:an other strange thing is polarity,
my MK47 is out of phase but I don't think it's a faulty wiring because when I check with a multimeter the Audio+ of the mic PCB goes to the PSU XLR out pin 2 ,
so what about the sound? is that the same color as your mics?
wave said:Adrian,
I haven't used our MK47 as a kit mic yet but the vocal test sounds a lot like mine and I'm using a different capsule.
Our DIY FET47 has more low end then our MK47 for sure.
Melodeath00 said:adrian said:an other strange thing is polarity,
I recently built a U47 (not the MK47), and my polarity was inverted as well. I just switched the audio wires inside of the PSU to fix it. Any reason you don't want to do that?
Thanks for the files by the way. I will listen soon.
wave said:Adrian,
Is that expected? I would think a U47 might have more low end than a FET47.
