I've ran an X32 Compact a few times per week for about two years now. It sounds okay but nevertheless still quite digital, and being the Compact model, you find yourself constantly switching between layers. It replaced a first-gen PreSonus StudioLive 2442 in the permanent installation, which sounded harsh, gritty, overly bright and digital in every sense of the words. But, while the X32 does sound better, the StudioLive was definitely far more ergonomic, AAMOF as easy as an analog desk to operate. And, I absolutely LOVED the native Capture and StudioOne software. Sadly, after about 10 years, some of the outputs became noisy and then failed altogether.
From what I understand, the latest Studio Live version has much better sound quality than the early ones, and of course now has on-board wi-fi and many additional tools and features. My advice was to get a new Allen & Heath or PreSonus, but those with the cash said someone told them the X32 was literally the best mixer ever built (face palm). Despite my more than three decades of experience playing in gigging bands and running live sound, I had no say in the matter; I was simply told to hook up the Behringer when it arrived, and get it up and running ASAP.
I still prefer to have a discrete gain control per channel ,
It allows me address sudden changes in level from the stage very quickly , no need to think ,hop and skip through menu's , same can be said of channel monitor sends , I like to be able to reach out and touch ,
I notice these days with modern digital mixers it takes longer for the engineer to fix problematic sources that are feeding back for instance , course you can always engage an auto sucking EQ on your outs ,but yeah they suck .
Yep, that's one of my biggest peeves with the X32, when dealing with either the Whispering Mic-O-Phobe who has a paralyzing fear of the mic and holds it 25" away, or else the Air Raid Siren with the 160dB voice who also naturally insists on eating the mic (usually while cupping it). In other words, situations where either the input preamp clips on the peaks or else diming the fader just ain't enough.
The PreSonus had dedicated input trim control knobs for every channel strip, while the X32 has exactly ONE shared between all the channels, plus a rotary encoder knob below the display screen that you can also use (if you can find it quickly enough). You must select the correct layer for that channel's bank if you happen to be in the wrong one, then the channel itself, and then select the preamp gain function or page, and then find the knob.
On the PreSonus, you could also, say, just reach up and roll off some low end to help deal with a chronic mic eater's proximity effect. Its Fat Channel had easily accessible, thoughtfully placed individual knobs for all the gain, dynamics and EQ for the selected channel. No matter where you were at, you just grabbed and tweaked it, whereas with the Behringer you have to individually select the EQ group function to access the high pass control.
The X32 is okay I guess, and I suppose it's a low-cost solution that does what it does pretty well. But, I just don't see why the world of pro sound has went so froot-loops crazy over it, like it was literally the greatest thing that's ever existed. Maybe I'm not seeing and hearing what they do, I dunno.
The Behringer does have far more bells, whistles and capabilities than the StudioLive did, but after living with it for a couple of years I still miss my old ride.
