burdij
I have been working on the prototype of a 500 series form factor parametric equalizer. The goal is to have a discrete signal chain, at least for the main signal path. Packaging in this form is a real problem, it appears, since making a single board solution to match the 500 spec creates a problem with the layout of a usable front panel.
The unit has four bands with a peak/shelf switch for the HF and LF bands and Q controls on the LF, ML, and MH bands.
Here is a picture of the DIY main board unstuffed and with most of the major parts in place.
