And in the meantime, I just started to get some parts for a decently apportioned bench PSU.
I've gone for this ebuy module http://www.ebay.com/itm/LV30B-5A-Variable-Positive-Negative-Voltage-Regulator-5A-1-5-30V-DIY-Kit-/222252198964?hash=item33bf436c34:g:~CQAAOxyhodRuzWJ
Its dual output, based on LM1084 LDV regulator for not too many dollars.
Supposedly can do a max of 5A and can do parallel/linked/bipolar operation depending on jumpering.
I'll hook it up to some 34-0-34 Vac secondaries and set it up for use as an adjustable up to +/-37Vdc at a max of 3A or so.
Or at a lower voltage and current most of the time. In a simple box with an old computer fan and a 200VA toroid etc.
It has power on delay relay protection, which is handy when flinging this much juice around in the hope some makes it to the speaker! Just the thing for bench testing. I'll be interested to see what ripple one gets at 1.5A per rail.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
It's worth the bother to get a better bench supply - I can see that discrete class A is where I'll be playing for a while, and the power gets chewed up pretty quickly ...
