Motown Direct Amplifier-inspired Preamp?
Possibly a cathode follower driving the WCF?
here is the scratch pad with an LA2a type circuit on the top, looks like too much gain unless you knock it down with dividers and NFB,
the bottom drawing is a Marshall type cathode follower feeding the WCF, and some NFB. this would cut down on the gain as the second part of the follower has close to unity gain,
i have an RCA 6BX7 on the way from evilbay,
there is also that Jensen line driver with the 6AU6 driver which might be interesting
    409.7 KB
I have never understood the fascination with the White follower. Yes, it has an incredibly low small signal output impedance but its main advantage is that it is push pull so we save a lot of quiescent current. Its biggest problem though is it has unity gain. This is why I prefer to use an SRPP output stage. It has the advantage of being push pull and it has a decent amount of gain. Its downside is higher distortion but the NFB takes care of that.
I have seen a version that has a phase inverter driving a WCF or SRPP, I forget which,
If the reissue is just using one 6V6, that says that the original did not use a white cathode follower, if they are using the same circuit.
This is how far I have got in making a V72 type circuit with a 6BX7 cathode follower.
Please note that it has both ac and dc feedback.
I will gradually fill in the circuit values and update as I go.
C4 may not be needed if DC connection is possible.
C6 would probably be around 2~5 uF and should be chosen to give a flat response with the resonance of the chosen OPT.
best
[I will gradually fill in the circuit values and update as I go] -- Good Deal!!! Looking forward to a completed schematic!!!
[ac and dc feedback] -- AC/DC were known for their feedback!!!
UTC HA 113 would work well for this project with the 200 mW level,
This dealer says there is a Cinemag output xfmr in there, probably the 2840 which would suggest a follower circuit,
12AT7 tubes are listed on another site, I bet the original used 12AX7's, maybe they wanted lower gain to compensate for the 6V6 being used in place of the 6BX7, strap the 6V6 for triode operation and you could probably use 12AX7's,
https://ardasuppliers.com/en-lv/pro...hSIj6XxkwOpBQVBjRk0q0PSi0W_fLhzTYNcfORXW9zE2d
Found a gut shot, non invasive,
Cool on the tube socket shock mounts !
The 6V6 being that close to the open frame xfmr worries me,
    170.6 KB
This topic sort of reminds me of an interview with Pino Palladino.
They are sitting in a studio and Pino has this beautifull fretless bass.
At some point the guy asks.. "can I play it ?"
"Yes sure" Pino says...
The guy plays this wonderfull bass and says .. "it sounds like me"
Pino replies "What did you expect ?"
:D
Yes that does sound different .
They use to split her voice, one channel was normal. The second channel was sent through a filter to extract the upper freqs of the hi end, then they would boost the crap out of it and combine it with the normal channel. That's why she had that shimmer on her vocs.
Years later somebody put that idea in a box and called it the aural exciter, although I think the method used was a bit different.
They had tricks for trying to make AM radio sound hi fi.
[Years later somebody put that idea in a box and called it the aural exciter] -- Back during the 1980's and 1990's, I remember reading more than one article mentioning that the guy who had started APHEX had built himself an audio preamp from a kit. He eventually happened to notice after awhile that the audio signal going into one of the inputs sounded differently than the same audio going into the other inputs (i.e., switched line-level inputs). So, he decided to back-trace his wiring of the preamp and then discovered he had made a wiring error when he had assembled the preamp.
I am assuming that his preamp kit may have been similar to one that I once owned that had the usual complement of stereo inputs, such as: TAPE 1, TAPE 2, TUNER, AUX, PHONO, etc. What this guy discovered as he back-traced his wiring was that the audio-signal of one of the inputs accidentally got routed into and through the phono-cartridge of his turntable. Since, for whatever reason, this audio had a pleasant and unique "shimmer" to it, he then began to experiment and research -- WHY -- the audio sounded "better" going through a phono-cartridge!!! The end result of his experimentation and research became the "APHEX AURAL EXCITER".
Anyway.....that's my story and I'm sticking to it!!!
Nice gut shot CJ. Looks like a regular octal rectifier tube. According that ChatGPT the output tube is a 12B4A (another double triode) and the mic pre tube is an EF86. Not sure what the middle on is but a 12AX7 would be my guess.
Nice one midnight. I have been using ChatGPT to find out what tubes are used. It says the first three (from left to right in your chassis) are EF86, 12AX7, 12B4A
It gets confused about the fourth tube (the rectifier). First it says it is a 6X4 (which is a small B7G tube), then it says it used a semiconductor rectifier, and lastly it thinks it is a 5AR4/GZ34 (which seems most likely).
The mains transformer (rear right of the chassis) seems to be a Hammond 309JX if my reading is right. Output transformer is a Cinemag and probably physically identical to their CM-2810 model.
Nice to see CJ getting stuck into metal bashing for this topic over on the Lab!
Here is an updated schematic, the only tube that would do the job is an ECC88/6DJ8.
I calculated that the gain of one tube un-by-passed times the gain of the other by-passed must equal or exceed 30dB. The ECC88 does just that leaving room for at least 20dB of NFB. Both tubes run at 2.5mA so the HT dropper passes 5mA x 10k =50V drop. The 47uF cap on V1B is 3dB down at 4Hz. (RK//rk =800ohms).
best
Hammond 369JX pwr xfmr
Cap is a JJ
But don't want to copy ACME, trying to make a 1 off of the original.
Sweetwater has the tubes listed as EF86, 2 ea. 12AT7, 6V6GT.
The EF86 was not on the original but added as a mic input for more versatility.
[The mains transformer (rear right of the chassis) seems to be a Hammond 309JX if my reading is right] -- You may need to get a new prescription for your glasses as there weren't any "309JX" transformers on the HAMMOND website. However, there was a "369JX" mains transformer as shown below:
EDIT: -- I just took a closer look at the photo of the chassis and its mains transformer and.....it is indeed a "369JX"!!! YAY!!! In any case.....this proves you do need a new prescription!!!
(I'm kidding!!!).....
EDIT-2: -- It took me so long to finish my first edit that CJ posted the correct transformer model in the mean time!!!
>> I have attached the "369JX" datasheet for your review.
-369JX -- 50 ------- 500V C.T. @ 69ma. --------------- 50 ------- 6.3V C.T. @ 2.5A ---------------
And, here is the link to the entire HAMMOND "300-Series" of power-transformers, should the "369JX" not be the correct one:
https://www.hammfg.com/electronics/transformers/classic/300
  • HAMMOND -- 369JX Power-Transformer Datasheet.pdf
    272.5 KB
Just a note, the 6BX7 is mentioned twice, once by by ptown and once by the acme guy as being the output tube on the original unit. This is on page 6.
It is also mentioned by ptown that the output stage has no gain. This would indicate a cathode follower. Since the 6BX7 is a dual triode, it seems logical to use it as a white follower aka LA2a, the high plate current would not be conducive to using the tube in parallel.
A regular cathode follower could have been used if the tube was used for 2 channels at once.
The choke is a Hammond 157G, as mentioned on page 1.
These long threads are conducive to info being lost and repeated.
Cap is a JJ
FWIW, this page:
http://www.analoganonymous.com/acme-motown-tube-di.html
(very similar-looking (earlier?) unit with a different layout)
lists two 12AX7s (other ones the same) instead of 12AT7.
There's also a top of chassis pic (I've brightened it since the can cap is difficult to make out in the original) :ACME Motown tube DI top of chassis pic_dsc00598_orig.jpg
(the original) :
http://www.analoganonymous.com/uploads/1/1/0/9/110989005/dsc00598_orig.jpg
best
I don't understand the purpose of R5.
There's also a top of chassis pic (I've brightened it since the can cap is difficult to make out in the original) :View attachment 137423
[(very similar-looking (earlier?)] -- Your photo of this chassis more accurately follows the drawing posted earlier than the other photo I had used in my Post #433.
>> Is it possible for you to provide a list of Part Numbers of the other transformers (i.e., HAMMOND 157G, CineMag CM-????, etc.), the large electrolytic capacitors and anything else used inside the chassis? That would prove to be highly useful with my trying to recreate the mechanical design details of this chassis. NOTE: I basically -- assumed -- the chassis height as being 1.50" high. Can you confirm what the actual chassis height is??? THANKS!!!
FYI:
