[quote author="Flatpicker"]Cat 5,
After re-reading my post today, I wanted to make sure I do not come across like I'm trying to discourage you from attempting this, but rather to keep you from messing up your board. You sound rather apprehensive and I was just trying to make the point that it does take a little skill. Gus offers some good advice. Practice on a junk board first and you'll do fine.
One more thing... Use a low temp iron/tip, if you have a choice as this will not cause the pads to lift as quickly.[/quote]
I understand Ti, and appreciate you looking out. I am not quite that much of an ameteur with building, as I am getting pretty good at soldering. I was planning on getting another 603 to do the royer tube mod on, so I will try the cap mod on the original circuit board before I take it out. The Royer mod completely replaces the board, so it won't be a loss if I screw up.
If it's easy enough, I'll do the matched pair with the new caps. You say it is a real noticable improvement? I was keeping an eye out for some KM84s to come available, but if the 603s get much better I can just live with them. I was really surprised at how good these mics sound.
I would probably just clip the old caps and remove the stems one at a time, then use a desoldering vacuum (the spring loaded kind with the button) or wick to remove solder from the holes.
Shouldn't be too hard I think. I have never lifted a pad yet, so I don't know how easy it is for that to happen.
Shane
Tim, got any music online I can hear that you made with your new mics? Some mandolin would be great too!
